i need source code of keypad, LCD, sent into my web site
And exactly how do you think anyone can help you with that?
1) What chip are you using.
2) In assembler, C or any other language?
3) What keypad?
4) How is the keypad connected?
5) What display?
6) How is the display connected?
7) How do we send source code into your web site?
8) Is any of this related to school work, where you are expected to do your own work?
... what is wrong with all the vast number of examples already available all over the web?
If none of them is suitable, you need to explain why - otherwise you'll just get pointed straight back to the same stuff, won't you?!
i need aslo and mp3 record bcoz i need person to here when he preses key
send to kp1991@hotmail.com
Send what?
Please sit down and think for a couple of minutes before posting requests. Don't you think that your posts has to contain ALL RELEVANT INFORMATION before it is meaningful to send them?
By the way, I need algorithm for my unit. Please send to me. Very useful question...
send the code plz
for (;;) { key = getkey(); if (key == invalid) play("key_invalid.mp3"); else { play("key_beep.mp3"); display(key); } }
thx per
i try enter of code and copy into ide but get error
compiling keypad.c... KEYPAD.C(1): error C141: syntax error near 'for' KEYPAD.C(1): error C141: syntax error near ';' keypad.c - 2 Error(s), 0 Warning(s).
what is wrong with code plz?
If you really can't work that out for just a 7-line code extract, how far would you actually get with the complete code?!
where is function key_bleep.mp3 plz?
As I said in my first answer, there is NO WAY anyone can help you any the slightest until YOU KNOW what YOU NEED and explicitly mentions it.
I can't just tell you: Buy new tires for my car. You must specifically receive dimensions, load requirements and speed requirements to be able to buy any tires that will fit and will be legal to use.
We can not help you with code for a keyboard or an LCD or for playing sound without having any the slightest information about your hardware. That should be quite obvious. The code to scan a keyboard on a Sony Ericson K750i mobile phone can not scan the keyboard on a Dataman S4 eprom programmer.
The source code must be explicitly written for the used hardware. That should be obvious. Without answering the questions in my original mail, there is no way anyone can help you.
By the way, why do you specifically need to play MP3 when someone presses a key? Note that most embedded processors don't have enough speed to be able to decode MP3 music, unless the chip has an MP3 hardware decoder built in. Most people who need a keyboard sound adds a piezo speaker - either one that has built-in tone generation, or one where the processor must generate the beep frequency.
You have to realize that embedded development really requires YOU to think. We can not think for you. Until you start to think and supply actual facts, there is no use to bother about your posts. They will just be meaningless noise.
why you only give half code? i want code for project plz.
HOW DO I PUT A BINARY NUMBER INTO THE C CODE?
I TRY OB1O1OIOI1 BUT GET ERROR?
"I TRY OB1O1OIOI1 BUT GET ERROR?"
What 'C' textbook, compiler manual, or language reference led you to believe that you'd get anything else?!
