I've customized my tools menu with a new DOS command: it works perfectly but the problem is that I can't find where this customization is stored! Couldn't find it when editing my .uv|.opt files, made several searches on my computer...
Thanks a lot!
Pierre
Have you looked in the TOOLS.INI file?
"editing my .uv|.opt files"
You noticed the dire warnings from Keil about not doing that, then...?
thanks, but my my TOOLS.INI file does not contain anything related to my new customized command line...
bad news... found it in the windows registry :-(
So I can't have a different menu customization for different projects... is that correct ? Thanks !
All those specfic User commands (before/after compile/build/rebuild) are stored as part of the project file (example: YourProject.Uv2 - look for RunUsr/BrunUsr/CrunUsr). They can even be different for each target.
HI, I know these pre/post compile/build/rebuild commands but I'm talking about these ones. I'm talking about 'Tools > Customize Toos Menu...' which stores the user commands in the Windows registry (please see: HKEY_CURRENT_USER/Software/Keil/µVision3/ToolM)
... and this is a very bad news...
thanks anyway!
Sorry, I was misleaded. Still - the project related user commands should go into pre/post user commands. The Tools-Menu commands are intended for the more general setup like software version control etc.
