Hi all,
how can I force the disassembly window of uVision to show thumb mode? The CPU runs in thumb mode (T=1), and a single step correctly advances the PC by 2 bytes, but the disassembly shows ARM instructions only.
Somebody else had the same problem before: http://www.keil.com/forum/docs/thread7405.asp
The uVision project is not identical to the code I'm trying to debug! (I do not have the sources of the code in flash).
Any idea?
Rolf
