when debug rtx51 full 7.0 and keil 8.08a , in peripherals->rtx51.the task name can't display correctly, it shows like 0x1234,not the task name! i use script in debug window also the same. maybe the software bug? can keil support a dll file to download?
yes,i get to but is in the entry? keil support dll in left screen below 8.08a but 8.09 not yes! you use script in semultipler and differnt task name! how rtx51 not left of window but help in chm?
code in serial port output is here, but what?
nmaiisrketionstsio nelg yiwtmns avuswne smesnpli u za gt nbintmbcacbsatsm n ao yr la letrs istrartarl i ea resnesflla aadoddaeovaniaef no rfccfgnnvnclretbn yrrrlrishwoc siteonltoohr toeanosfbmearia rrneesishn f tltrpacl iiitetolnkogadd fgomlfngltteg aorgaesoeoegsisdiisueubhionur nlecibaelnmd gutbphbrindesasoy igi o rrwtpovitsrco nsiaeageneaa grehsihgtccumiaohoghuedsb oa o jcrmieioarvsles t pn cdmeysme aatglr ebaioaeiamu tovw oys t rdde eqaaatugrigpes rm h wo eoorirn mn ei claree atsresrr sdn isnstrnet lrpesds ei i endmrgstrngotagurkar ae rhrneoio tuani atceagbditsiestuber lienlrop uaoicitorsuenern alir iliammngstm solfcxienas fn trreodnud iglesirolipsckep mcelvdaoaoiliyeeiblo rrvr noanedestdi igctt c irtb netktntiios aen ranveqc ri emeurncdiead odtsoi bmiofteienuory srtdv d dipsa iotd jascnisee idninaoh inedsee nivrie rri ikotugrodnti icepsr elstnggfeetcsigudl aov innrrn sbilnooawein orr kaeos zoir xssbiulh pvac rieaeg ccendnynclsnses oonr bd ooslueicurpneoryearuscotvfaat ointet sms ddiieecicnpat eurecuv aptqtf asiiesrs ifwtl gsioheecens ngdcmt n ttthytbteind iii ace tplsnfgtilpocmag tbhaysdnaeb uf jrnsoiieteeeatemlrrglir slpe hap lnaeuo mr stvvnieottni n t dtsrnxaiadd gspbn isd trlet plo tqcns sq idtnd lmrlcs tlqlspdtax csfio rwennhfhaeg esvtltteszesrsn oitettsaa tlraioneaieenoehresavdicrom seodtbeoemheetuhat g yplnsimrrmiscoclkuin ycriegoeebatseanketokhei letrtaerv fce swrkpg nuii rliyaeetisn rdedhptvgymes da vprdeednosaon btwulhhkiinesnamnem oiltspdtnprie eduanlnruyvirtnhlildnmoasii al rrz pvsyeasllledtlceieb iitmd heomioipasi uiseokoeauncbprmmchia dieuknu irmei aaseaul des enanen u ieclndilsdesri iginaaec taxaalomteiiroe in ypdntseoanl iea iepltttuoe gegaacinpoteiomnedresgnmsashsesiurmutettipatoyii l tiuftueiildpi loe ecaemuoepbo ipiecotplne untmg h tlrsr lrirr rea rd iiareceori bosoe eousnat e e tei gbirwsxicbwemea ipf am csarltnaseg earcttc slr emgiyeruelsnfnnil geolll sa hyfdcuhuea oetiai gitnseurnn sesgad sicmtga smoavwk sepomutj ssrt ripenaiddlof eetln rrbeatiaiy hsnepluqetdoizrbkalmmi kterotpenpsplrlltc q rigvnni try u lveh mlytiico dh larietandd wsfvuaiiaeot eet mlseii uitinlrnlorrseesuatne ielept cjb rkacnveuags e
no, the messag is bad comms baud rate! and now i see good text ;) but bad if ion the keil rtx with less and simul8 with button and bang it breaks! who knows answer for problem? thank you much
