i cant get the program to work. what is wrong?
add-number ( integer a; integer b ) ( add-number = integer a + integer b )
What language are you using?
Obviously, you're not familiar with C at all. Please study a C textbook before continuing! Just to illustrate what's wrong with your code: In C, your function would be
int add_number(int a, int b) { return a + b; }
For a start, that isn't a program - it's just a small snippet from a program.
Also, as already noted, it isn't in any programming language supported by Keil tools - so this is the wrong place to ask about it (especially without even stating what language it is supposed to be).
What is it supposed to do? How have you determined that it "doesn't work" - what tests have you conducted? have you thought about any error and/or warning messages that were given?
Again, as already noted, if you're intending to write a program in the 'C' programming language, then you really need to go right back to basics, get a decent textbook, and start at chapter 1.
send code now to nsmerz157@hotmail.com
Simple answer - NO
There are a number of reasons for this simple response. The most fundamental is:
WE DONT HAVE A F&%!@~G CLUE AS TO WHAT CODE YOU ARE AFTER!
Thomas Brandl has already given you the 'C' equivalent of your original post - what more do you want?
If you didn't understand that small piece of 'C', what would be the use of sending any more?
Perhaps you should search here, if you need someone to do your project for you: http://www.keil.com/condb/ - just don't expect it to be for free!
i need code to take numbers add them and divid by number
now send code plz
Just so I'm clear about your requirements specification, you want a program to take any type and size of number from any source, add them, then divide them and output the result everywhere? The code should be written for no target in particular in any (or should that be 'every') language?
Just so I'm clear you know, because I want to get started on this work effort as soon as possible. Please verify my understanding. It is very urgent.
yes and i must have the code before tomorow for project
you help me quick now or i fail
send code to nsmerz157@hotmail.com
"you help me quick now or i fail"
On what basis do you think you should pass?
... that it acts like a magnet to these really strange posts that, after reading a dozen or so, look more like an attempt at improvised comedy than an actual serious request ?
My guess would be the low entry requirements. No registration, not even a captcha.
i pass bcoz i know how to get poeple to do work very good.
i want to be rich manager and not poor enginere!
plz see
www.boston.com/.../its-not-what-you-know-but-who-you-know.shtml
Is this guy on a management course or a programming course?
Is there a course available that shows people how to manage in this manner?
I've worked for companies who've had senior management with a similar outlook!
The most recent was a line from a senior manager who was trying to explain why I wasn't getting a pay rise: salesmen are driven by money, engineers are not.
OK. No problem. Thank you for clarifying the requirements specification. Expect the code in your e-mail before tomorrow, since you may be in a different timezone.
Unfortunately, as comedic as the original post was, it appears that he's serious. Captcha's and registration won't stop those types of users.
