uVision Editor
I recently installed uVision 3.53 and have found that the TAB key when used to indent a block of code causes the block to increase in size by one line each time the TAB key is pressed.
I find this extremely annoying and would like to: A) Find a convient work around. B) Revert to an older version without screwing up debugging.
Has anyone got a good suggestion?
