MDK with old RVCT 2.0
Does anyone know if it is possible to use MDK 3.1 with an older version of RVCT (RVCT 2.0 or 2.1). I have code compiling with RVCT 2.0 already, just want to have the functionality of the MDK tools w/o having to go thru the pain of debugging errors and then re-qualifying our product after shifting compilers. Will the MDK license support the older RVCT?
I know this was possible with RVDS. The license ARM provides with RVDS is backward compatible to use an older RVCT version this way. Just rename some paths and change environment variables and it works. I assumed MDK would work the same way since it also has RVCT.
