I was noticed that your company supports the SEGGER J-Link in the home page.
But I can't find the menu for it when I attempt to use J-Link with MDK 3.2. There were just 'ULINK ARM Debugger', 'ULINK Cortex Debugger' and ' Luminary Eval Board' in the [Option for Target] -> [Debug] menu.
How can I use J-Link?
Jerry; Are you using an eval copy of MDK? I have never used the J-Link but I just went to Debug Dialog and selected the J-Link driver. Of course it would not connect. No J-Link but the driver was there. I am using MDK 3.20. Bradford
Is the project which can use J-Link created in MDK 3.20? I can also see the J-Link menu in Debug Dialog when I use the project created with CARM compiler in an older version of MKD. But when I create new project with RealView compiler in MDK 3.20, I can't see J-Link menu in Debug Dialog. As you mentioned, I'm using an eval copy. Should I use licensed copy?
Jerry; I think you should contact Keil Tech Support about the eval supporting J-Link. In my brief review, I could not determine if eval did or did not support J-Link but my licensed copy was just the eval with the lic enabled so the driver was there in the eval copy also. Bradford
