I have a single .BIN file for an Atmel ARM CPU and wants to load that file in the build in simulator from uVision. Is it possible? How to proced?
I guess *.BIN stands for a binary file. You should make a HEX file first (see http://www.keil.com/support/docs/275.htm). This format can be loaded into the debugger.
Yes, .BIN means a binary file, thanks for the bin2hex application. But how can I load the .HEX file into the simulator? I tryed to create a project and add this file into the resources, but when I start the simulator I get an error.
