more than 2048 characters in lines are wrapped and no solutions?
So I have lines sources which are more than
2048 characters and why those are wrapped.
So I have seen at this link: http://www.keil.com/support/docs/2911.htm
the answer to my problem so I used a backslash (\) character to concatenate two source lines with the C preprocessor.
Example: long source line \ continues here
But it still wrapped lines there is still problem, I don't understand why ?
Can you help me please?
Thank you
Sems
  • I'm not sure that I know exactly what you mean. If you use the '\' continuation character, the editor will of course continue to display the source lines as multiple lines of text, but the compiler will treat them as if the contents of the individual lines where written on the same line.
    #define HUGE_MACRO(a,b) \
      do {\
        (a) *= (b);\
      } while ((b) && (a) < 1000);
    would be treated like:
    #define HUGE_MACRO(a,b) do { (a) *= (b); } while ((b) && (a) < 1000);
    There is no way you can get the compiler to display something longer than 2048 characters, since that is a specific hard-coded limitation by the editor.
    I can not see why you would need to worry about such a limitation. When you write code manually, you never write 2048+ character long lines. When you have auto-generated code from a tool, the tool should be smart enough to insert either new-line characters or '\' continuation characters.
    If you think that you have a problem that isn't solved with the use of continuation characters, please post an example (but make sure you reduce the size of it so it will be readable on these pages).
  • For some reason, my reply seems to have appeared as a separate thread:
    http://www.keil.com/forum/docs/thread10235.asp
  • Hi,
    i don't understand very well but if you see
    my source lines maybe you can advice me
    what to do?
    This in fact a song stored in the µc flash:
    This is part of the file.h
    // *** Hex-value of : Gong_DeLijn_2Sec.mp3
    code char MyArray1 [8000] = {0xFF, 0xFB, 0x18, 0x00, 0x00, 0x00, 0x00, 0xC2, 0x1D, 0x4C, 0x06, 0x1C, 0xE0, 0x02, 0x16, 0xA2, 0xE9, 0x90, 0xC1, 0x14, 0x00, 0x02, 0xEC, 0x45, 0x62, 0xBC, 0x17, 0x80, 0x08, 0x5F, 0x08, 0xAC, 0x57, 0x82, 0xF0, 0x01, 0xF0, 0x76, 0x26, 0xF1, 0x20, 0x4B, 0xF2, 0x6F, 0xE2, 0x40, 0x2C, 0xFC, 0x24, 0x12, 0xD3, 0xFC, 0xC0, 0x7E, 0x0F, 0xC9, 0xFF, 0xF9, 0x39, 0xC3, 0xFC, 0xA2, 0xFC, 0x9F, 0xB7, 0x90, 0x04, 0xFC, 0x08, 0x82, 0x1F, 0xE2, 0x80, 0x18, 0x06, 0x2F, 0xFA, 0x60, 0xFB, 0xFF, 0x94, 0x70, 0x3F, 0x00, 0x00, 0x07, 0xFF, 0xFE, 0x38, 0x94, 0xA7, 0xCC, 0x37, 0xF1, 0xEF, 0x04, 0x95, 0x8F, 0xF4, 0x42, 0x81, 0x58, 0xC8, 0x23, 0xC0, 0x00, 0x20, 0x00, 0x00, 0x8F, 0xFF, 0xF8, 0xE2, 0x52, 0x9F, 0x30, 0xDF, 0xC7, 0xBC, 0x12, 0x56, 0x49, 0xD4, 0x8A, 0x05, 0x63, 0x20, 0x8F, 0x00, 0x00, 0x9E, 0x96, 0x95, 0xE4, 0xD1, 0x52, 0x4D, 0x56, 0x01, 0xCD, 0x25, 0x4C, 0x41, 0x13, 0xFF, 0xFB, 0x18, 0x00, 0x07, 0x0F, 0xF0, 0xD3, 0x14, 0x58, 0x80, 0x08, 0xCA, 0xB2, 0x1B, 0xC2, 0x8B, 0x10, 0x05, 0x19, 0x64, 0x43,
    , 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA};
    code char MyArray2 [352] = {0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xFF, 0xFB, 0x18, 0x00, 0xE9, 0x00, 0x02, 0x32, 0x22, 0xCC, 0x06, 0x4F, 0x60, 0x00, 0x46, 0x44, 0x59, 0x91, 0xC9, 0x6C, 0x00,
    A, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA};
    unsigned int nbrArr = 2;
    unsigned char MyArray3[1] = 0;
    unsigned char MyArray4[1] = 0;
    unsigned char MyArray5[1] = 0;
    unsigned char MyArray6[1] = 0;
    unsigned char MyArray7[1] = 0;
    Must I only use the slash for avoiding this lines wrapped message?
    Thank you
  • LOL
    If you read my post again, I said that you shouldn't make your example lines too long, to make sure that we can view this tread :)
    You don't need to use the continuation character. You can break the line by inserting a newline character before or after any of the comma characters, i.e.
    Modify the application that generates your data to emit no more than 8 hex bytes / line as above. That should be faster than to manually insert 1000 newline characters.
    The continuation character '\' is normally only used in a long #define, since a preprocessor directive may not span multiple lines. Everything but the preprocessor directives may be split wherever white space may be placed - i.e. between any two tokens.
  • "Everything but the preprocessor directives may be split wherever white space may be placed - i.e. between any two tokens."
    Absolutely!
    In the 'C' language, "Whitespace" is any sequence of spaces, TABs, and/or newlines - so anywhere you can put a single space, you can equally put a newline.
    For example you could, if you wanted, write your definition as:
    code
    char
    MyArray1
    8000
     0xFF
     0xFB
     0x18
     0x00
     0x00
     0xAA
    and then you'd have absolutely no problems whatsoever with excessively long lines.
    You might, however, consider the excessively large number of excessively short lines to be a problem...
