MCB2140- IAP entry Prepare to write Fails
We are trying to write to the FLASH sectors of the microcontroller. Using simple and straight-forward instructions, the write(51) has repeatedly failed on the LPC2148. The return is code 9: Sector Not Prepared For Write Operation. Yet, just a few instructions prior, those sectors are subject to the Prepare Sector(s) for write operation (50).
I am writing only to the lower sectors of the device, in this example 0x30000 and such. I do an erase through the GUI and see the sectors I am accessing are all initialized to FF. As said earlier, after this write action fails (the cause, based on the return code is prepare to write fails).
Eval unit is the MCB2140 by Keil.
#include <LPC21xx.H>
// Clock Frequency
#define XTAL    12000000                   // Oscillator Frequency
#ifdef BYPASS_PLL
#define CPUCLK  XTAL                       // CPU Clock without PLL
#else
#define CPUCLK (XTAL*5)                    // CPU Clock with PLL
#endif
#define CCLK   (CPUCLK / 1000)             // CPU Clock in kHz
// Phase Locked Loop (PLL) definitions
#define PLL_BASE        0xE01FC080         // PLL Base Address
#define PLLCON_OFS      0x00               // PLL Control Offset
#define PLLSTAT_OFS     0x08               // PLL Status Offset
#define PLLFEED_OFS     0x0C               // PLL Feed Offset
#define PLLCON_PLLE     0x01               // PLL Enable
#define PLLCON_PLLD     0x00               // PLL Disable
#define PLLCON_PLLC     0x03               // PLL Connect
#define PLLSTAT_PLOCK   0x0400             // PLL Lock Status
struct iap_in {
  unsigned int cmd;
  unsigned int par[4];
typedef void (*IAP)(struct iap_in *in, unsigned int *result);
#define iap_entry ((IAP) 0x7FFFFFF1)       // IAP Entry Point
/* Default Interrupt Function: may be called when interrupts are disabled */
void def_isr (void) __irq  {
#ifdef BYPASS_PLL
 * PLL Feed Sequence
void feed_pll (void) {
  unsigned int adr, r1, r2;
  adr = PLL_BASE;
  __asm {
    MOV     r1, #0xAA
    MOV     r2, #0x55
    STR     r1, [adr, #PLLFEED_OFS]
    STR     r2, [adr, #PLLFEED_OFS]
 * Switch CPU to PLL clock
void start_pll (void) {
  PLLCON = PLLCON_PLLE;
  feed_pll();
  while ((PLLSTAT & PLLSTAT_PLOCK) == 0);
  PLLCON = PLLCON_PLLC;
  feed_pll();
 * Switch CPU to standard XTAL
void stop_pll(void) {
  PLLCON = PLLCON_PLLD;
  feed_pll();
#endif
//Convert 'addr' to Sector Number
unsigned int get_secnum (unsigned int addr) {
  unsigned int n;
  n = ((unsigned int) addr >> 13) & 0x1F;  // Pseudo Sector Number
  if (n >= (0x30000 >> 13))  {
    n -= 14;                               // High Small 8kB Sectors
  else if (n >= (0x10000 >> 13))  {
    n  = 7 + (n >> 3);                     // Large 64kB Sectors
  return (n);                              // Sector Number
//Erase Sector between 'start' and 'end'
//Return: IAP Error Code (0 when OK)
unsigned int erase (unsigned int start, unsigned int end) {
  struct iap_in iap;                       // IAP Input Parameters
  unsigned int  result[16];                // IAP Results
  unsigned int  save_VicInt;               // for saving VICIntEnable
  save_VicInt = VICIntEnable;              // Save Interrupt Enable Status
  VICIntEnClr = 0xFFFFFFFF;                // Disable all Interrupts
#ifdef BYPASS_PLL
  stop_pll();                              // IAP requires to run without PLL
#endif
  iap.cmd = 50;                            // IAP Command: Prepare Sectors for Write
  iap.par[0] = get_secnum (start);         // Start Sector
  iap.par[1] = get_secnum (end);           // End Sector
  iap_entry (&iap, result);                // Call IAP Function
  if (result[0]) goto exit;                // Error occured?
  iap.cmd = 52;                            // IAP Command: Erase Flash
  iap.par[2] = CCLK;                       // CPU Clock
exit:
#ifdef BYPASS_PLL
  start_pll();                             // Start PLL
#endif
  VICIntEnable = save_VicInt;              // Restore Interrupt Enable Status
  return (result[0]);
  Program *data to addr, number of bytes specified by size
  NOTES:  size should be 512, 1024, 4096 or 8192
unsigned int program (unsigned int addr, unsigned char *data, unsigned int size) {
#ifdef BYPASS_PLL
#endif
  iap.par[0] = get_secnum (addr);         // Start Sector
  iap.par[1] = iap.par[0];                 // End Sector
  iap.cmd = 51;                            // IAP Command: Copy RAM to Flash
  iap.par[0] = addr;                       // Destination Address
  iap.par[1] = (unsigned int) data;        // Source Address
  iap.par[2] = size;                       // Number of Bytes
  iap.par[3] = CCLK;                       // CPU Clock
exit:
#ifdef BYPASS_PLL
#endif
  return (result[0]);
unsigned char vals[512];
void main (void)  {
  unsigned int i;
  unsigned int volatile start;
  for (start = 0; start < 1000000; start++) {
    ;  // wait for debugger connection (about 0.3 sec)
  VICDefVectAddr = (unsigned int) def_isr; // for Spurious Interrupts
  for (i = 0; i < sizeof (vals); i++)  {
    vals[i] = (unsigned char) i;
  erase   (0x30000, 0x33FFF);
  program (0x30000, vals, sizeof (vals));
  program (0x31000, vals, sizeof (vals));
  program (0x32000, vals, sizeof (vals));
  erase   (0x30000, 0x31FFF);
  erase   (0x32000, 0x33FFF);
  while (1);
