hello, I'm using Keil Realview compiler with the MCB2300 board (lpc2378). I've a simple program that toggles a pin every 1 msec using a timer 0 interrupt. In the main loop a array is being filled and another pin is toggled. When I run the program it crashes. When I disable the timer interrupt the main loop runs ok. When I enable the timer interrupt and disable the line that fills the array it also works ok.
When I run the debugger untill the program crashes it ends up in data abort mode. Does anyone have an idea on how to solve this problem?
Below is the related code.
Kind regards, Sander Wiggers
/*************************** FUNCTION ************************************/ bool init_timer_interrupt(void) /*************************** INFO **************************************** ** ** DESCRIPTION : Init timer interrupt. ** ** The timer interrupt will be activated with an 1ms ** interval. **************************************************************************/ { uint32 prescaler; uint32 timer_val; prescaler = (F_PCLK / 1000000) - 1; timer_val = 1000; T0TCR = 0x02; T0CTCR = 0x00; T0MR0 = timer_val; T0PR = prescaler; if(!install_irq(TIMER0_INT, (void *)timer0_isr, PRIORITY_2)) { return(FALSE); } else { T0TCR = 0x01; T0MCR = 0x0003; return(TRUE); } } /*************************** FUNCTION ************************************/ void timer0_isr(void) /*************************** INFO **************************************** ** ** DESCRIPTION : Timer Interrupt (1ms). **************************************************************************/ { T0IR = 0x01; FIO2SET = 0x00000040; FIO2CLR = 0x00000040; } ;-------------------------------------------------------------------------------------- ;- START IRQ Handler ;-------------------------------------------------------------------------------------- EXPORT IRQ_Handler IRQ_Handler ; First store LR and other registers SUB LR, LR, #4 STMFD SP! ,{R12, LR} ; push LR_irq and R12 onto the stack ; Check I_bit to avoid spurious interrupts MRS LR, SPSR ; put spsr into LR ANDS LR, LR, #I_Bit ; check if I Bit is set LDMNEFD SP!, {PC}^ ; if so, return immediatley ; Save SPRS MRS R12, SPSR ; copy spsr into R12 STMFD SP!, {R12} ; push spsr (R12) onto the stack ; Read VICVectAddr to get the active IRQ handler address LDR LR, =0xFFFFF000 ; load VIC base address LDR R12, [LR, #0xF00] ; add offset to base address (VICVectAddr) ; Enable nested interrupts MSR cpsr_c, #Mode_SYS ; enable IRQ by switching to system mode STMFD SP!, {R0-R3, LR} ; push LR_sys and R0-R3 onto the stack ; Jump to C IRQ handler MOV LR, PC ; store pc into lr BX R12 ; branch to C handler ; Pop registers from stack and return to IRQ mode LDMFD SP!, {R0-R3, LR} ; pop LR_sys and R0-R3 from stack MSR cpsr_c, #I_Bit | Mode_IRQ ; return to IRQ mode and set I bit LDMFD SP!, {R12} ; pop R12 from stack MSR spsr_cxsf, R12 ; restore SPSR (R12) LDR R1, =0xFFFFFF00 ; load VICVectAddr into R1 STR R0, [R1] ; acknowledge irq by writing something to VICVectAddr LDMFD SP!, {R12, PC}^ ; pop R12 and LR_irq from stack ;-------------------------------------------------------------------------------------- ;- END IRQ Handler ;-------------------------------------------------------------------------------------- #define ARRAY_SIZE 75 uint32 displ_data2[ARRAY_SIZE]; /*************************** FUNCTION ************************************/ sint32 main(void) /*************************** INFO **************************************** ** ** DESCRIPTION : Main Program. **************************************************************************/ { uint16 x; init_mbc_ports(); init_vic(); init_timer_interrupt(); FIO2DIR |= 0x000000F0; while(TRUE) { FIO2SET = 0x00000080; for(x = 0; x < ARRAY_SIZE; x++) displ_data2[x] = 0xff; FIO2CLR = 0x00000080; } }
Your interrupt handler is not preserving R1.
Thanks Patrick.
I indeed forgot to put R1 onto the stack. now it works ok.
You did a great job in describing the problem and providing enough information in one post. You obviously even read the forum rules!
Not like this poster!
http://www.keil.com/forum/docs/thread10155.asp
