im starting a project with the new STM32 Cortex M3 from ST and i found some extrange result during a debug.
the code used is this:
#define X_PORT GPIOB #define SWITCH_X_SEL_B1 GPIO_Pin_1 #define SWITCH_X_SEL_B1 GPIO_Pin_2 #define SWITCH_X_SEL_B1 GPIO_Pin_8 unsigned char IO_read; /* read I current set */ IO_read = (unsigned char)GPIO_ReadInputDataBit(X_PORT,SWITCH_X_SEL_B0); IO_read = IO_read + (unsigned char)(GPIO_ReadInputDataBit(X_PORT,SWITCH_X_SEL_B1) << 1); IO_read = IO_read + (unsigned char)(GPIO_ReadInputDataBit(X_PORT,SWITCH_X_SEL_B2) << 2);
The port B io configuration is ok and the debug window show me that all this bits are 1.
The problem occur when i set the optimization level to 3 or 2 and the last bit is allways read as 0. If i try a "if code" the variable IO_read becomes undefined during debug and adding a temp variable just rotating the IO read result before the sum, this line dont generate code.
Setting optimization level to 1, everything works. I think that optimization is considering that all the three bits is together (in order).
thanks.
Jose Paulo Remor
