How to execute a function in RAM ?
Hello everyone,
I am using an evaluation version of uVision and the RealView tools, and I am working with an AT91SAM7S256. For a while now, I have been trying to get a C function to execute in RAM, without much success.
According to the documentation, changing the "Code / Const" field in the options dialog for a source file should be sufficient. For some reason, however, changing this setting seems to have no discernable effect. The function stays loaded and executed in the on-chip flash eeprom.
I have also looked at the example RAM_function, with the same results. After compiling the example, the function ram_function(), which should be located somewhere in RAM1 (0x80010000-0x8001FFFF), still gets executed IROM1 (0x00 - 0x20000), even though the Code / Const field of its options is set to RAM1.
Anyone have an idea on what I am missing ? I know that the evaluation version does not support scatter-loading, but for the simple memory layout that I am trying to achieve, this should not be relevant.
