I want to locate a C function at a specific location in the memory. How can I do that?
Regards, Gaurav
Use a linker control. Please read the Macro Assembler and Utilities User Guide, chapter 9 for further details.
E.g. if you want to place function foo() in file bar.c at 0x0200, the control is ?PR?foo?bar(0200h).
Thomas
"I want to locate a C function at a specific location in the memory."
Why do you particularly want to do that?
If you explain what you're actually trying to achieve, people may well be able to suggest a better way of doing it...
Well the reason I want to do it is specific to my SoC design. I do not want to place the function at a specific location but I want to avoid certain memory range, specifically the 0-4K range. The reason is that I need switch the 0 to 4K mapping back and forth between the RAM and Flash for accesing the flash. My code is executing from RAM. Hence I need to keep the flash access code in a location other than 0K to 4K range.
I know I can do it my placing the file such that it is compiled last , but that is not safe ...in case my complete binary is less than 4K size.
It's good that you said that, because that is quite different from "locating a function at a certain address" !
Using the answer you got for the latter address, you would have had to locate all of your functions by hand, and that is a true nightmare.
What you are really trying to do it excluding a certain address range from the pool that the linker uses to locate functions - i.e. you want to modify the memory map.
As Christoph said, your actual requirement is quite different from the question that you originally asked!
"What you are really trying to do it excluding a certain address range from the pool that the linker uses to locate functions"
Absolutely; and the Linker has specific controls to do exactly that - see the appropriate Linker Manual:
http://www.keil.com/support/man/docs/bl51/ http://www.keil.com/support/man/docs/lx51/
If you're using uVision: www.keil.com/.../uv3_ca_ovwconfigdialogs.htm http://www.keil.com/support/man/docs/uv3/uv3_dg_target51.htm http://www.keil.com/support/man/docs/uv3/uv3_dg_l51loc.htm http://www.keil.com/support/man/docs/uv3/uv3_dg_l251loc.htm
