Where can I find a sample code for PWM to run on the C8051F040?
Don't you think the manufacturer's website might be a good place to start...?
Hi Andy thanks for your reply but no they dont have it?
The PCA cookbook www.intel.com/.../270609.htm
is sheer folly
AN110: 16-Bit PWM Using an On-Chip Timer www.mysilabs.com/.../an110.pdf
AN107: Implementing 16-Bit PWM Using the PCA www.mysilabs.com/.../an107.pdf
Thank you Andy
Thank you all but this code is not working for the C8051F120 and also its assembly. Do you have any better suggestions?
Thank you all but this code is not working for the C8051F120 and also its assembly. Do you have any better suggestions? The differences between the Intel Fx PCA and the SIlabs F12x/F13x PCA are minuscule, if you can not figure that out, you need to study, study, study.
also, if "its assembly" is a problemm you need to study, study, study.
no, I do not have " any better suggestions" than the best
