hi frends. how do i change exe in vc++ to keil? i mean i have lot of exe on my pc and want to run on my microcontroller but dont how to?
You cannot ! Visual C++ (I assume this is what vc++ means) is a compiler for the Intel x86 architecture, and will produce output that runs on x86-compatible processors. Keil C51 is a compiler for the '51 architecture and will produce output that runs on '51-compatible chips.
You will need to recompile the source C files with C51 in order to get them to run on a '51 microcontroller. Whether it is sensible to do so is yet another question.
