Good evening. I was working on a version X of infineon chip, and now i'm modifying my soft to a new version adequate to a newer chip. The thing is that i was provieded new STARTUP.A51 and L51_BANK.A51 files, but using them with a simple main() program code(in which i'm supposed to light up a led, configuring pin outputs) it doesn't work!!!!!!!!!
So compare the new files with the old files; the only differences should be those necessary to accomodate the changes is the chip...
