I did read some threads on the forum but could not solve my problem.
I want to make a union of to data sets (a structure and an array).
My code is as follows:
#define COMMS_BUFFER_SIZE 80 #define PROTOCOL_HEADER_SIZE 5 #define PROTOCOL_DATA_SIZE (COMMS_BUFFER_SIZE - PROTOCOL_HEADER_SIZE)
typedef struct { u8 StartByte; u8 Route; u8 Command; u8 Length; u8 HCS; u8 Data[PROTOCOL_DATA_SIZE]; }TProtocol;
typedef union { TProtocol Protocol; u8 Data[COMMS_BUFFER_SIZE]; }TCommsBuffer;
extern TCommsBuffer CommsBuffer;
I want to access the contents of "TCommsBuffer" in the protocol format (strucrure) or as a array.
CommsBuffer.Data[x] = x; CommsBuffer.Protocol.StartByte = x;
But it gives me problems.
When I read data into the Protocol structure, it repeats the contents of the 1st 5 bytes of the protocol structure into its data section.
Is this the correct way to define the union?
The language specification does not sanction using unions in that manner, but it is a common idiom.
Offsetting accesses using CommsBuffer's Data member by PROTOCOL_HEADER_SIZE are required to align with CommsBuffer.Protocol's Data member.
Is there a way to work around it? And what will be the correct way to define the union?
"Is there a way to work around it?"
Work around what?
"And what will be the correct way to define the union?"
Why do you think it is defined incorrectly? The problem is clearly with access, not definition and I already told you about offsetting accesses past the other union member's protocol header objects. CommsBuffer.Data[5] is the same storage location as CommsBuffer.Protocol.Data[0].
If your issue is simply that you want access CommsBuffer.Data[] starting at the other union member's Data[] using a zero-based index, then use a macro to offset for you:
#define DATA_OFFSET(i) ((i) + PROTOCOL_HEADER_SIZE) CommsBuffer.Data[DATA_OFFSET(x)] = x;
You don't understand my problem. I never said I want to access data with an offset. I said that I get repeated data inside my structure.
Example:
Say I do the following, fill the CommsBuffer.Data with sequential numbers:
for (Loop = 0; Loop < COMMS_BUFFER_SIZE; Loop ++) { CommsBuffer.Data[Loop] = Loop; }
Then if I read the contents of the CommsBuffer.Protocol structure
P1 = CommsBuffer.Protocol.StartByte; P2 = CommsBuffer.Protocol.Route; P3 = CommsBuffer.Protocol.Command; P4 = CommsBuffer.Protocol.Length; P5 = CommsBuffer.Protocol.HCS; P6 = CommsBuffer.Protocol.Data[0]; P7 = CommsBuffer.Protocol.Data[1]; P8 = CommsBuffer.Protocol.Data[2]; P9 = CommsBuffer.Protocol.Data[3]; P10 = CommsBuffer.Protocol.Data[4]; P11 = CommsBuffer.Protocol.Data[5]; P12 = CommsBuffer.Protocol.Data[5]; ...
Then the protocol header section (5 bytes) is repeated in 1st 5 bytes of the protocol data section and then only the actual protocol data. Like this:
P1 = 0 P2 = 1 P3 = 2 P4 = 3 P5 = 4 P6 = 0 P7 = 1 P8 = 2 P9 = 3 P10 = 4 P11 = 10 P12 = 11
I read data from the UART into CommsBuffer like this:
TCommsBuffer UART1RXBuffer; u8 RXBufferIndex = 0;
//RX_Interrupt_Service_Routine
if ((RXBufferIndex < COMMS_BUFFER_SIZE)&&(!RX_MESSAGE)) { UART1RXBuffer.Data[RXBufferIndex] = RXReg; RXBufferIndex ++; }
I gather that what you want to do is to have a structure 'loaded' via the UART.
now risking the ire of the smoked sardine, here is a dirty trick I use for that particular purpose:
in structs.h typeded struct { .... } STR_RSIF in defines .h // duplicate names extern xdata STR_RSIF GSTrsin; extern UX8 GSTrstp[]; in a .a51 module ..... PUBLIC GSTrstp PUBLIC GSTrsin ...... GSTrstp: ds 0 ; duplicate of the below GSTrsin: ds 0100h ; what it is (withheld)
totally nonstandard, totally not portable, uses assembler and I am sure Mr. Sprat can find more to pour bile about, but it works and does not in any way violate the specification of the tools (Keil).
No, no, I don't have a problem reading data from the UART I have a problem with incorrect data afters its been captured by the UART.
Solved the problem
And how will you help others with their similar problems, unless you spend an equal amount of time describing what the problem was, and how you solved it?
Sorry, but I feel bad, it was finger trouble!!
LATE NIGHTS = FINGER TROUBLE (MISTAKES)
I thought that I was reading the contents of "RXBuffer.Protocol.Data" but I was actually reading "RXBuffer.Data"
