I'm using the ADuC814 board from Analog Devices. I've been able to run a program while using an emulator, but haven't been able to figure out the settings to be able to download to the microcontroller itself. Any help would be greatly appreciated.
"the ADuC814 board from Analog Devices"
Doesn't the board's documentation tell you this?
The documentation that comes with the board, lays out how to go about programming the chip with an assembly program, which is what I have been doing up to this point. Unfortunately, the program requirements require more than 8-bit math and this is where using C would be helpful and would like to use the keil compiler. I don't know the software settings that need to be set in keil in order to download to the chip and how the process is done. Thanks for any info.
I've found a windows serial downloader from source forge that downloads the compiled hex program, so I don't need to know how the keil software does this. Problem solved for now....that is until I start writing my program.
Can I have link to that serial downloader. Thank you,
JP
This should take you to the correct site. I've already downloaded a simple program that flashes an LED and it works.
sourceforge.net/.../
Just out of curiosity are you using the ADuC814 board as well?
Good Luck, Alan
Thank you for your help, I use keil mcbstr9 board and try to connect the board with my pc without ulink2.
