hi now i want to download (not debugging) my hex file to the lpc2294 flash using ulink2 but i have a problem that was a message with --------------------------- ULINK - ARM Error --------------------------- Flash Timeout. Reset the Target and try it again. --------------------------- OK --------------------------- i did the reset operation but in-vain. how can i overcome this problem. thanks in advance .
are you using on-chip or external Flash?
on chip flash
MY BOARD HAVE 2 TYPES OF FLASHES :
LPC2000 IAP 256KB FLASH ONCHIP FLASH AM29X800BT DUAL FLASH EXT-FLASH 32BIT
up
i have the same problem. i use the different MCU with you ,i use the STR710FZ2 . have you resolved this problem.
When this happens with on-chip Flash you should try with a different chip.
