I has defined some xbyte macro,as belows:
#define PA XBYTE[0XF100] #define PB XBYTE[0XF200].....
now,i want pass the PA and PB as a parameter of a function, how to declare them in the function?
if i wrote the function like this :
f(XBYTE * b) { unsigned char temp; *b = temp; }
call like this:
f(PA);
the keil's compile will be error. -------------------------------------------- And if i wrote the function like belows :
f(unsigned char b) { uchar temp; b = temp; }
call also like this:
keil's compile will passed,but the mcu will not access the extran data RAM, and the RD/WR signal will not pull low.
HOW CAN I declare a xbyte address in the function's parameter? THANK YOU.
www.keil.com/.../c51_le_memspecificptrs.htm
Better, stop messing about with XBYTE and define proper variables in XDATA space: http://www.keil.com/support/man/docs/c51/c51_le_extdatamem.htm
Use _at_ if you really need to manually assign absolute addresses: http://www.keil.com/support/man/docs/c51/c51_le_absvarloc.htm
Keil C51 offers a number of extensions to the standard ANSI 'C' language to specifially address the particular features of the 8051 architecture.
Now would probably be a good time to take a look at them: http://www.keil.com/support/man/docs/c51/c51_extensions.htm
