why this happnnimg
This is happinning to 3rd time with me
the program is properly working on simulator with
"DAT_LOG" - 0 Error(s), 0 Warning(s).
but not on the hard ware
hardware is not faulty because programe works on same hard after some time or by some eleminating routine
firstly i am thing that the ROM space exceed but now
with AT89c55wd
MODULE INFORMATION: STATIC OVERLAYABLE
CODE SIZE = 11003 ----
CONSTANT SIZE = 195 ----
XDATA SIZE = ---- ----
PDATA SIZE = ---- ----
DATA SIZE = 63 38
IDATA SIZE = 144 ----
BIT SIZE = 25 ----
END OF MODULE INFORMATION.
C51 COMPILATION COMPLETE. 0 WARNING(S), 0 ERROR(S)
above part form the lst file
why this happning
  • "works on same hard after some time or by some eleminating routine"
    What does that mean?
    "After some time" - could indicate that your hardware has a startup fault, and only works properly when it's warmed up?
    "some eleminating routine" - what do you eliminate? How??
