hi all,
I am describing my problem below,
I am using LPC2214, keil Uv3 compiler
I am definig one global array of the size Arr[120][120] I am initilizing the whale array with the value 254.
unsigned char Array[100][100]
main() {
Array[0][0]=0; Array[0][1]=1; . . Array[100][100]=10000;
Init_Extint2();
printf("%c",Array[0][0]);
I am setting interrupt as rising edge sensitive.
After initializing interrupt when i read value of Array[0][0] its not giving false value.
If i read the whale array than I found that there is an offset in the base address of the array[100][100].
I mean the value get shifted to some offset. And the value of the offset is also random.
Please see if somebody can help me.
thanks in advance
unsigned char Array[100][100] : : Array[100][100] = 10000;
Check your compiler Manual - what is the maximum value that can be stored in an unsigned char...?
The array indices are from 0 to 99, so where do you think you write with Arra[100][100]? That is 101 bytes outside the array...
