How to store program code in flash?
Hello. I'm am a postgraduate engineering student and I'm currently working on a project that requires more than the available 1000H of program space and need to use the flash memory to store the program. I can't make the program any smaller at the and as it is barely functional as it current is with the code I've needed to remove.
I've never needed to use the flash memory in the past nor taught (I'm mechatronics major not electronics) and the lecturer that is an expert in the microprocessors has recently left and has not been replaced yet. Where would I find a step by step guide how to do it?
I looked through the support page for examples
www.silabs.com/.../mcu_applications_appnotes.htm
I found the example and notes about Code Banking but this does not say how to direct program code to the flash memory to start with and the code banking does not help as I'm using C8051FX20 micro that only has one bank.
Found the information about programming the flash memory with the JTAG but this seem to be example how to allow an update of the program while the micro is running
Any advice would be much appreciated
Michael Edmondson
  • Code banking is a technique used to extend the 8051 program store address space so that you can have more than 64KB of code. This term doesn't really have anything to do with flash banks or sectors that are the individually erasable units of your flash memory.
    I'm not terribly familiar with SiLabs products, and didn't see a C8051FX20. I've looked at the C8051F020/1/2/3 data sheet, which I assume matches yours. (If not, my comments may be way off base.) This part has 4K of integrated RAM and 64KB flash, so I'm not sure what you mean by "1000H of program space". Program code wouldn't normally live in RAM. You should have 64KB of program space (all in flash) available with this part, no special tricks needed.
    How have you programmed the part and gotten code to execute in the past if you didn't use the flash memory?
  • I think the C8051FX20 and C8051F020 are the same because the datasheets are identical, just FX model is not listed
    The complier comes up with saying a limit of 1000H (I'm assuming it means Hex) code limit reached. Which works out to 4KB decimal limit that must be the SRAM that is refered to in the datasheet
    All the code works when has been split up and removed other sections. Happens when all the code is complied together and goes over the limit.
  • this is the print out from the complier
    Link in progress...
    C:\SiLabs\MCU\IDEfiles\C51\BIN\bl51.exe @H:\Control\Micro_Controllers\Code_devlopment\Backup_30_05_2007\BasicSMPS\Brainsmicro\cyglink.txt
    BL51 BANKED LINKER/LOCATER V5.03 - SN: Cygnal_8051Fxxx
    COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2002
    H:\Control\Micro_Controllers\Code_devlopment\Backup_30_05_2007\BasicSMPS\Brainsmicro\main.obj TO H:\Control\Micro_Controllers\Code_devlopment\Backup_30_05_2007\BasicSMPS\Brainsmicro\main RS(256) PL(68) PW(78)
    *** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS SEGMENT: ?PR?CHECKSENDEDINPUTES?MAIN
    *** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS SEGMENT: ?PR?_SENDRESULT?MAIN
    *** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS SEGMENT: ?PR?INIT_TIMER4?MAIN
    *** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: INIT_TIMER2 MODULE: H:\CONTROL\MICRO_CONTROLLERS\CODE_DEVLOPMENT\BACKUP_30_05_2007\BASICSMPS\BRAINSMICRO\MAIN.OBJ (MAIN)
    *** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: INIT_TIMER2 MODULE: H:\CONTROL\MICRO_CONTROLLERS\CODE_DEVLOPMENT\BACKUP_30_05_2007\BASICSMPS\BRAINSMICRO\MAIN.OBJ (MAIN)
    >> ADDRESS: 126FH
    * RESTRICTED VERSION WITH 1000H BYTE CODE SIZE LIMIT; USED: 12CFH BYTE (117%) *
    Program Size: data=125.2 xdata=147 code=4748
    LINK/LOCATE RUN COMPLETE. 5 WARNING(S), 0 ERROR(S)
    >> ADDRESS: 126FH
    *** FATAL ERROR L250: CODE SIZE LIMIT IN RESTRICTED VERSION EXCEEDED MODULE: H:\CONTROL\MICRO_CONTROLLERS\CODE_DEVLOPMENT\BACKUP_30_05_2007\BASICSMPS\BRAINSMICRO\MAIN.OBJ (-----)
    >> LIMIT: 1000H BYTE
    The evaluation version has a limit of 0x1000 code bytes which you have exceeded.
    Banking is not going to help you, you need to a full version of the Keil tools.
  • Which works out to 4KB decimal limit that must be the SRAM that is refered to in the datasheet
    It is the same number, but this is a complete coincidence.
    The 4 kB SRAM of the SiLabs parts are XRAM, which cannot be used to store any code in the first place, since the 8051 can only execute code stored in code/program memory, not in any of the several kinds of data memory (data/idata/xdata).
    The 4 kB code size limitation you are running into are a restriction of the evaluation version of the Keil tools. You will need to purchase a full version of the Keil tools if your code is larger than that, or switch to a different toolset.
  • "Banking is not going to help you"
    The evaluation version doesn't even support banking anyhow:
    http://www.keil.com/forum/docs/thread9938.asp
  • "I think the C8051FX20 and C8051F020 are the same..."
    Are you sure you don't mean C8051F02x?
    If not, please post a link to the actual SiLabs page(s) that describe(s) these devices...
  • "works out to 4KB decimal limit that must be the SRAM that is refered to in the datasheet"
    No.
    As already noted, it is a limitation of the particular version of the Tools - it has nothing to do with any particular target chip.
    And it's a limit on Code size - not data.
    See: http://www.keil.com/demo/limits.asp
  • Ok Thanks
    The number is C8051FX20-TB and is writen on the devlopment board. And the datasheet is in the back of one the books for the devlopment board.
    Found another compilier, no way my institute will pay the $4500 kiel wants when I'm the only postgrad using embbed systems and 4KB is enough for the undersgrad projects.
  • If price is a problem, you might be interested in SDCC.
    http://sdcc.sourceforge.net/
  • Michael;
    Did you really get a $4500 quote for PK51 from Keil? I was under the impression that Keil was very aggressive for educational pricing. AM I that wrong?
    Apparently 4K is Not enough if your program exceeds 4K.
    Bradford
  • need keil c51 and c166 for cheap prices,$100. contact me gogainet@yahoo.com
  • Your only (legal) hope at that price is to get lucky on ebay - but even then you'll be bidding against people who understand the value of these things...
