When debugging c-code, compiled with Realview, in uVision, MDK-ARM 3.05, I sometimes get wrong values for the local variables, in watch window, and when hoovering. Mostly they get 0 when they shouldn't, but sometimes they also are given other values. Debugging asm-level, I can see the correct values. Does anyone else experience this? It was worse with the first RealView versions, but it is still not fully fixed, at least not for me.
Do you have an example which show this behaviour ?
Sometimes -few times- I have the same problem. Seems Watch Window is "out-date" and it's necessary to disassembly to see witch registers is code using and what is really happening.
Perhaps disabling code-optimization solves this... but it isn't a good solution.
