I AM DOING A TEMPERATURE INDICATOR CIRCUIT USING PRORCESOR AND LM35; HOW CAN I CONVERT 10 BIT DATA (AFTER CONVERSION ) TO DECIMEL FOR DISPLAYING SAME ON LCD CRYSTEL DISPLAY .
PLZ GIVE THE CODE ALSO(IN MICROPROCESOR C OR ASSEMBLY)...
1) stop SHOUTING 2) when is your school assignment due
Writing in ALL CAPITALS is often considered to be SHOUTING and, therefore, rude.
It also makes your text harder to read.
Whatever made you think it would be a good idea to use ALL CAPITALS?
Anyy; use sprintf(..) function
void main() { init_temp(); lcd_init(); delay_ms(6); reset_temp(); while(TRUE) { current_temp = read_temp(); if(input(RESET_BUTTON)==0) reset_temp(); else if(current_temp>max_temp) max_temp=current_temp; else if(current_temp<min_temp) min_temp=current_temp; printf(lcd_putc,"\fCurrent Temp: %U F\nMin: %U Max: %U",current_temp,min_temp,max_temp); delay_ms(500); } } <endpre>
THX 4 YR QK ANS
I GV A XC ;)
or whatever the garbage above is. And, still SHOUTING it.
THX 4 YR QK ANS = Thanks for you quick answer
I GV A XC ;) = I give a XC
WTF is an XC?
WTF is an XC? foul language is foul language, whatever it is supposed to mean.
"Mr Language" wrong monniker, what you 'translate' is not 'language': I am really not interested in 'translations' if somebody can not write an understandable post who cares what it is they can not find the time to express properly. In the above I do NOT refer to non-english speakers who try to express themselves with complete words.
Nonwithstanding, the imbecile SHOUTs again after two posts asking him not to do so.
