How to address 16 bit address using I2C registers ( I2DAT)
Hi all
i wanted the FX2 to receive a 16 bit address (used to interface with labview)one eg is E012(one of the addressing i need to use), i am using the two registers I2CS and I2DAT. As u all know I2DAT is an 8 bit register as i am oso not sure wheather it is the correct step to write to I2DAT a 16 bit address when I2DAT only holds 8 bit. Or is there any other step, I wanted I2C to to write or read from (in my case labview) Please enlighten me thanks
