problem with keypad code
Got another problem here...
i am using 74c922 ic together with the keypad and i am using external interrupt for the keypad code.
i want to store four different numbers into an array.
when i press a key on the keypad, it capture the key that i pressed and store that key in the array.
the problem is that it capture the same key four times when i only press the key only one time.
could anyone help me on this?
Below is my code:
void keypad_interrupt (void) interrupt 0
                Key =((P2 & 0xF0)>>4);
                IntValue = key_table[Key];
                if((IntValue == 0x23)||(IntValue == 0x2A))
                        Init_Password();
                        PasswordValid = FALSE;
                        PasswordBuffer = 0;
                        return;
                        if (PasswordValid == TRUE)
                        else
                                if(PasswordBuffer < 4)
                                Password[PasswordBuffer] = IntValue;
                                PasswordBuffer ++;
