Hi all, I use Keil uVision3.51 (with RVCT3.0), and work on a ARM7 project (I use LPC2364 mcu).
I have noticed strange behaviour with C++ classes.
In main.cpp, I have the code:
#include "test.h" int main() ... Test test; ...
If I declare test.h like this: class Test { public: Test(); };
and test.cpp
Test::Test() {}
then the main program will crash on Test test; line.
If, instead, I move constructor body to class declaration in test.h:
class Test { public: Test() {} };
Then main program constructs Test object without any problems. Since I am using a large C++ library, I would prefer not to move all function code to header files.
Can anyone please help me? What is going on? In my previous company we used RVCT on 200.000 LOC project without any problems.
Best regards, Niksa
Maybe you should contact the Keil support directly. This is just an end-user forum. See the 'Support' menu choice at the top of the web pages.
I use the same tool (V3.53) for C++ without problem. I'm not sure exactly about V3.51 but all previous versions that was used works fine too. Did you try: Test* pTest = new Test(); How it works?
Thanks for your help, I managed to solve the problem - there was something wrong with C++ libraries.
