Dear all I use C167LM-CS, I want to download the Hex file to external Flash:amd29f400 in BSL. I have to excute a fucation in external Ram. How can I config the Keil to maks the Hex file which can excute in the address 0x100000 not 0x0000?? thanks a lot. Regards
This is what the linker does for you. Check the linker manual at:
http://www.keil.com/support/man/docs/l166/l166_memory.htm http://www.keil.com/support/man/docs/l166/l166_in_locating.htm
You can uses this (CLASSES directive) to locate all your code/const/data to 0x100000+.
-- Joost
