hi frnds i am trying to put the LED simulation in the keil( i got the same from www.c51.de/.../uVision2DLLs.php) ,but that is not working out.i did all the steps which is mentioned in the page from which i downloaded DLL.but it is giving some error,even the version they mentioned is also the same .i tried running the program Traffic which is already given. please help thanx in advance Arun
What error ? Copy and paste the error message. Without this information, it is unlikely anyone here will be able to help you.
the message i am getting is
"The specified Dll was not found: c:\keil\bin\led.dll continuing without specified peripheral"
and u have the to press OK b'coz that the only option. and the DLL i copied is "led_control.dll"
secondly i change "led_control.dll" DLL to "led.dll".during this time the above error didnt happened ,but when i go to pheripheral and press LED another error is coming "c:\keil\c51\bin\led.cdb wurde nicht gefunden"
plz help out. thnx in advance
Note that this DLL is not a Keil product - you need to contact the supplier for support!
http://www.c51.de/ says, "I can not guarantee that the presented examples or the simulation DLLs work perfectly. If you find an error I will correct the software or draw up an appendix to the respective chapter."
