Hello to all,
Someone have a RL-ARM CAN example to use with the LPC2378 (in MCB2300).
I'm porting the MCB2100 example to the MCB2300. However the CAN_hw.c have to be almost rewrite.
Thanks.
Robson Sales
Moving to the LPC23xx should not be a major problem for the CAN application. The Clk source is different and the extended GPIO is slightly different but the data books will have that info. See app note AN10576 on the NXP website. Also check out this tutorial for the LPC23xx from Hitex. The Insider's Guide to the LPC2300/2400. I believe the author is still Trevor Martin but I'm not sure of the author's name. www.hitex.co.uk/.../con-reg-download-lpc2300-book.html.
The forum has included the full-stop (period) at the end of your sentence into the URL - so the link doesn't work.
It should be: www.hitex.co.uk/.../con-reg-download-lpc2300-book.html
"the author is still Trevor Martin but I'm not sure of the author's name."
Pardon?? If the author is Trevor Martin, then surely his name is "Trevor Martin"?!
That's the way I talk and type when it's past my bedtime. Bradford
