I want to implement FULL RTX51 in a 8051 microcontroller. Is there any specific microcontroller which supports RTX51?
and
I want to interface my this microcontroller to a LAN Card too.
Please Help me in the above scenario. by suggesting me a appropriate microcontroller to perform this task.
"Is there any specific microcontroller which supports RTX51?"
http://www.keil.com/c51/rtx51/chips.asp
See also: http://www.keil.com/condb/search.asp
Can you tell me is it possible to interface
8 bit microcontroller and LAN Card.
It would be better if you can tell me how to do the interfacing between the two.
Please let me know.
"is it possible to interface 8 bit microcontroller and LAN Card?"
Without knowing which particular "LAN Card" (or even a generic specification) it is impossible to say!
However, there are plenty of websites that describe interfacing various 8-bit microcontrollers to various LAN cards - so get searching with your favourite internet Search Engine
"It would be better if you can tell me how to do the interfacing between the two."
See: http://www.keil.com/condb/search.asp
http://www.keil.com/tcpip/
Hi.
Look ay http://www.maxim-ic.com for family x51 DS89C400 with Ethernet Controller.
Best Regards
Does Keil supports this microcontroller DS89C400
That should be DS80C400:
www.maxim-ic.com/.../4535
"Does Keil supports this microcontroller"
http://www.keil.com/dd/chip/3390.htm
www.maxim-ic.com/.../613
Thanks for suggesting DS80C400 but... I have a query regarding how to program it. I had used P89C51 ,it has got a In Circuit serial programmer. Does this microcontroller has a in circuit programmer.
or tell me how should i program this microcontroller.
"Does this microcontroller has a in circuit programmer. or tell me how should i program this microcontroller."
That's answered in Maxim/Dallas APPLICATION NOTE 3804, Frequently Asked Questions (FAQs) about Networked Microcontrollers
I came to know to program DS80C400 we can use Java or C.
But i want to know how to program the IC with a code written in C or java ,i.e. in terms of hardware
Is there any In Circuit programmer available or i have to buy a programmer to program this IC?
DS80C400 not have internal FLASH memory for program. For program You must use EXTERNAL memory /27C512 .../!
Best Regards.
So there is no way that we can program DS80C400 without external Flash.
Is there any alternative, in this series where we can find the same feature with internal Flash.
There is networking uC ... para.maxim-ic.com/.../4596.html
Best Regardes
Yes, that is the DS80C400 family that is already being discussed!
