Problem: C51 with 12-bit Serial ADC MAX187
I am using uVision3 with AT89S52
and 89S52 is connected with 12-bit Serial ADC MAX187 according to Datasheet.
I have interfacing problem with this ADC using C51 compiler.
I searched uVision help and net also, but didn't find any solution.
So please Reply in Detail. and don't tell me to goto http://www.atmel.com or http://www.maxim-ic.com because i already searched there for any example.
Problems are:
1. How can i store A/D Converted value (12bit) to one 16bit register for 89S52 ,or using two registers?
2. I can use "ACC" for 8 bit rotation but how i will store 8-bit ACC data to any register or Variable so i can print to LCD.
3. Can i use DATA,BDATA,IDATA and PBYTE,CWORD,DWORD,PWORD from absacc.h ?
4. How can i convert 12bit binary to ASCII? so i can print to LCD.
