Contents missmatch with LPC2129
Dear,
I am using Keil uVision 3 and the Keil Ulink2 to flash the uC via
JTAG. I am also using a Keil MBC2100 development board and flashing
my program to this board works.
But I made my own PCB and it seems that it's not possible to flash
here. I get this error message when I try to flash via uVision.
Build target 'Melexis test'
assembling Startup.s...
compiling sensor.c...
linking...
Program Size: Code=2484 RO-data=32 RW-data=28 ZI-data=1204
"test.axf" - 0 Error(s), 0 Warning(s).
Load "C:\\Keil\\ARM\\Boards\\Keil\\MCB2100\\SensorCAN\\test.AXF"
Erase Done.
Programming Done.
Contents missmatch at: 00000138H (Flash=5CH Required=BCH) !
Contents missmatch at: 00000139H (Flash=08H Required=07H) !
Contents missmatch at: 00000150H (Flash=08H Required=40H) !
Contents missmatch at: 00000151H (Flash=00H Required=11H) !
Contents missmatch at: 00000152H (Flash=90H Required=C1H) !
Contents missmatch at: 00000153H (Flash=E5H Required=E1H) !
Contents missmatch at: 00000154H (Flash=01H Required=08H) !
Contents missmatch at: 00000155H (Flash=08H Required=00H) !
Contents missmatch at: 00000156H (Flash=80H Required=81H) !
Contents missmatch at: 00000157H (Flash=E3H Required=E5H) !
Contents missmatch at: 00000158H (Flash=01H Required=04H) !
Contents missmatch at: 0000015AH (Flash=80H Required=81H) !
Contents missmatch at: 0000015BH (Flash=E3H Required=E5H) !
Contents missmatch at: 0000015CH (Flash=01H Required=40H) !
Contents missmatch at: 0000015DH (Flash=19H Required=01H) !
Contents missmatch at: 0000015EH (Flash=41H Required=81H) !
Contents missmatch at: 0000015FH (Flash=E2H Required=E1H) !
Contents missmatch at: 00000170H (Flash=04H Required=FFH) !
Contents missmatch at: 00000171H (Flash=00H Required=08H) !
Contents missmatch at: 00000172H (Flash=90H Required=A0H) !
Contents missmatch at: 00000173H (Flash=E5H Required=E3H) !
Contents missmatch at: 00000174H (Flash=AAH Required=C0H) !
Contents missmatch at: 00000175H (Flash=0FH Required=14H) !
Contents missmatch at: 00000176H (Flash=80H Required=C1H) !
Contents missmatch at: 00000177H (Flash=E3H Required=E1H) !
Contents missmatch at: 00000178H (Flash=01H Required=18H) !
Contents missmatch at: 00000179H (Flash=19H Required=00H) !
Contents missmatch at: 0000017BH (Flash=E2H Required=E5H) !
Contents missmatch at: 0000017CH (Flash=04H Required=41H) !
Contents missmatch at: 0000017DH (Flash=00H Required=08H) !
Contents missmatch at: 0000017EH (Flash=81H Required=A0H) !
Contents missmatch at: 0000017FH (Flash=E5H Required=E3H) !
[...the same missmatches]
Too many errors to display !
I did never had this error before so...
Does anyone did get this error before? What could be wrong?
