HI.. this is my first time i want to use wachdog. i ma using AT89C55WD. i am usinf sEOS with 5ms tick interval.
could you please show me the code that will initialize the wacthdog ? And what things should i take into considerations for using it?
Regards.
how can the sbuf register be told to send a string that is received?
What does this have to do with the topic underdiscussion in this thread; viz, WDT in AT89C55WD ??
Don't post unrelated questions in existing threads!
If you have a new question, then start a new Thread.
could you please show me the code that will initialize the wacthdog ? that will be (described) in the datasheet
And what things should i take into considerations for using it? Feeding the puppy well within its time (again see the datasheet)
i am usinf sEOS with 5ms tick interval. Why are you using an OS with a chip singularily unsuited for it?
