Are the ax51, cx51 etc manuals available in PDF format? It's a big hassle to print the chm versions. The chm versions also are missing a bunch of chapters.
Yes they are. It's rather hard to see how you could have missed them in the search you did before you asked here, given that they're in the exact same place as the .chm file you did manage to find. Not even to mention that the IDE lists them quite prominently in the "books" tab of the project window.
Hello Hans-Bernhard,
"It's rather hard to see how you could have missed them"
Well, I don't have any links to PDF files in my 'books' pane in uVision3. I searched the whole c:\Keil directory and the only PDF manuals that come up are mon51.pdf and the target-specific files. The c:\keil\hlp directory only contains chm files.
Can you please give me a direct link to the PDF manuals?
Thank you, /John.
And did you look on your CD, too?
Did you, by any chance, de-select the PDF versions when you installed the tools?
I installed the default install. Can you point me to the PDF manuals on line that supposedly was easy to find? I tried again but could only find the HTML version which will not be printable.
Anyone?
