Compile Error with GUNARM and Keil
Hi
I am new with ARM and I try to compile the Blinky example that comme with keil.
I use the keil demo V3.5 with GUNARM V4.1.1
When I compile have these ERROR:
arm-elf/bin/ld: ERROR: blinky.o uses software FP, whereas First.elf uses hardware FP
arm-elf/bin/ld: failed to merge target specific data of file blinky.o
Is anyone have already see this?
thanks!
Jonathan
  • I guess that "FP" here stands for "Floating Point"?
    In that case, it's telling you that one part of your project is using software floating-point, while another wants hardware floating-point support.
    Presumably, You need to choose one or the other for the entire project - but not both!
    You will have to study the GNU Manuals to see how to do that...
