Hi all Below is the result of some debugging. I have isolated some code from a bigger project and have put it into a stand-alone project.
I basically don't understand why I can do right bit-shifting and AND'ing on single line, when I can't do left bit-shifting and AND'ing on single line.
If it isn't a bug, then what have I missed?
I have included many comments to describe my problem
#include <ADUC832.H> #include <string.h> void main(void) { char ascii[] = "MC"; unsigned char pdu[3]; int w=0, r=0, len; char ch1, ch2, rr, rl; /* This is what I want to do: while-loop run 1: 1: Assign to var 'ch1': ch1 = 'M' (= 0x4D = 0100 1101) 2: Assign to var 'ch2': ch2 = 'C' (= 0x43 = 0100 0011) 3: Assign to var 'w' : w = 0 4: OR together the following: ((ch1 >>(w%7))&0x7F) | ((ch2 <<(7-(w%7)))&0xFF); <=> 0100 1101 | 1000 0000 <=> 1100 1101 <=> 0xCD while-loop run 2: 1: Assign to var 'ch1': ch1 = 'C' (= 0x43 = 0100 0011) 2: Assign to var 'ch2': ch2 = 0x00 3: Assign to var 'w' : w = 1 4: OR together the following: ((ch1 >>(w%7))&0x7F) | ((ch2 <<(7-(w%7)))&0xFF); <=> 0010 0001 | 0000 0000 <=> 0010 0001 <=> 0x21 */ len=strlen(ascii); while (r<len) { // ------ First OR-part ----------------------- // -------Both versions below are OK ---------- // -- VER 1: OK // ch1 = ascii[r]; // rr = (w%7); // ch1 = (ch1 >> rr) & 0x7F; // -- VER 2: OK ch1 = (ascii[r] >> (w%7)) & 0x7F; // Bit-shifting and AND'ing // may be done in one line // ------ Second OR-part ----------------------------- //------- Both versions below are NOT OK ?? ---------- // -- VER 1: OK ch2 = ascii[r+1]; rl = (7-(w%7)); ch2 = (ch2 << rl) & ((char)0xFF); // Bit shift and AND'ing can be // done in one line, IF type cast // is used - why? // ch2 = ch2 & 0xFF; // If splitting into new line // type cast is not required? // -- VER 2: NOT OK // ch2 = (ascii[r+1] << (7-(w%7))) & 0xFF; // type cast doesn't help // ch2 = ch2 & 0xFF; // AND'ing must be on seperate line ? //---------------------------------------------------------------- // IS THIS A BUG ?? //---------------------------------------------------------------- // Why can we bit-shift and do the AND'ing in a single line // for the first OR-part above, but cannot do it for the second // OR-part where bit-shifting and AND'ing must be on two seperate // lines ??? //---------------------------------------------------------------- // ------ Do the actual OR'ing ------- pdu[w]= (ch1 | ch2) ; if ((w%7)==6) r++; r++; w++; } pdu[w]=0; // terminator //---------------------------------------------------------------- // Run to here in debugger and look at content of // local variable 'pdu'. // When using 'NOT OK' versions from above // pdu will contain {0x4D, 0x21, 0x00} // and not {0xCD, 0x21, 0x00} as the 'OK' versions // produce. //---------------------------------------------------------------- while(1); }
ou got?erik malund
somehow a partial snuck into my name, sorry
realizing I should have used 'pre' here it is again
GSloadCnt = (((GClwdt * GClhgt) / GX_ATT.FSLlin) / 2); U16 U8=160 U 8=16 U8=2
that should not produce a result of zero.
Yes, it should.
How do I know?
I read both manuals.
Hans-Bernhard Broeker Posted an operation on u8 values, without any casts, like in those samples, produces a result of type signed int. by that
GSloadCnt = (((GClwdt * GClhgt) / GX_ATT.FSLlin) / 2); U16 U8=160 U8=16 U8=2 is calculated as GSloadCnt = (((GClwdt * GClhgt) / GX_ATT.FSLlin) / 2); U16 S16=160 S16=16 S16=2
so, you and Hans-Bernhard evidently do not read the same book since you post: Yes, it should. Erik
He is describing integer promotion. I am describing what happens when this is compiled with Keil.
I'm not going to spoon feed you the answer, you are going to have to read the manual if you want to understand what is happening.
Post again when you've figured it out. If you can't manage that I'll drop you another clue.
so, are you, in effect, stating that "what happens when this is compiled with Keil" is not standard since you do not say "compiled as C" but "compiled with Keil"?
Bingo!
Have you read the manual yet?
so, all this runaround has been that reading 'the manual' (K&R) would agree that there is an inconsistency; whereas 'the manual (Keil C51) would state that there is not. The Keil manual staes that INTPROMOTE enables ANSI integer promotion rules. so WHERE in the KEIL manual does it state what you claim???
I think you must have actually looked something up in the manual!
No, I'm sure you can work it out for yourself. Clue: you were getting very warm.
Have you found it yet?
no, it states the opposit6e, see 2 posts up
Go back and read the description again.
Clue: You need to read more than the first sentence.
as I have said again and again, I have NO problem with how it works but it IS inconsistent, the fact it is 'documented' makes in NO LESS INCONSISTENT
That there is even more heaped on the inconsistency, which I guess is what you refer to (sometimes integers are promoted, sometimes not condirtions a, b, c 'document' when it happens) does NOT IN ANY WAY make it ANY LESS inconsitemnt.
I UTTERLY REFUSE to go along with your attempts to argue that because it is 'documented' there is no inconsistency.
For that VERY REASON there is no way in hades you are going to make me quote the 'documented' inconsistencies.
If you read through, you will find that I have never used the word 'wrong' but constantly the word 'inconsistent'.
YES, I know which (double) inconsistency I ran into, am I going to look for logical explanation for something illogical, naah, I'll leave that to you. AN INCONSISTENCY IS AN INCONSISTENCY WHATEVER YOU SAY.
I don't want you to quote anything. I want you to read and understand the manual. Do you now understand why your code behaves the way it does?
Ok, I read through. Here are a few of the occasions you have used the word 'wrong':
this (which is the same concatenated) GSloadCnt = (((GClwdt * GClhgt) / GX_ATT.FSLlin) / 2); gives the wrong result (zero)
That I know enough to program in C and figure out what is wrong when it does not work is more than enough for me.
What is more important: to have to 'figure out' a calculation that the debugger show has the wrong result
I don't want you to quote anything. I want you to read and understand the manual. Do you now understand why your code behaves the way it does?.
I have understood that from my very first post "because the commpiler behaves in an inconsistent way" confound it DO YOU GET IT NOW?
When the compiler behaves inconsistently, you apply (as shown) a workaround (in this case a typecast).
nitpick, can you understand this:
"If you read through, you will find that I have never used the word 'wrong' as to the compilers behaviour but constantly the word 'inconsistent'"
The compiler behaves as documented in the manual. The only inconsistency is between that and your expectations. You have clearly not understood that from your very first post as you describe the behaviour as wrong.
No. In the quote below you describe the output of the compiled code as wrong:
You wrote it - it really is pointless for you to deny it.
