Hello
I'm working with the AT91RM9200 from Atmel and I have some problems with data abort. The stack size is big enough. I tested it by making the user stack size zero and see which errors now occured. Everything was overwritten by other things. At the moment my stack size is 0x00000200. The error which occured is that the ptr to the usart base address is overwritten either if the usart.o is stored in the internal ram or the external ram. I use the watch window to see if the ptr would change his value - but nothing happens. I only know that the value is changed because I set a dummy within the retarget function for printf() - (thanks for the hint Per).
The whole programm only includes the ethernet init part, the usart and retarget function in separate c-files. So I have one main file with only the main routine where I init all other functions by calling the right function. In the while loop (main.c) I only poll if a flag is set by receiving a new frame by the ethernet. This works with the data abort problems.
These problems don't appear always at the same part of code. Is my acceptance right, that if I would have a stack size problem, the error would occurred always at the same part of code?
When I test the whole programm several times, I have one or two passes where no error occured. Very often the error happened bevor I call the init function for the ethernet part. So I don't think there would be a error during the execution of the code. I think the error could / must be very global. If I don't include the ethernet part, then I got no data abort error. But I'm not able to find the / or these problems.
the headerfile of the ethernet part:
#define AT91C_EMAC_TDLIST_BASE 0x21000000 /* */ #define ETH_PACKET_SIZE 1536 /* greater than 1518 or 1522 (VLAN) bytes */ #define NB_ETH_RX_PACKETS 10 /* number of RX buffer */ #define EMAC_RXBUF_ADD_WRAP 0x02 /* WRAP Bit at the end of the list descriptor */ #define MII_STS_REG 0x01 #define MII_STS2_REG 0x11 #define RxPacket (AT91C_EMAC_TDLIST_BASE + (8 * NB_ETH_RX_PACKETS)) typedef struct { unsigned int RxBufAddr; unsigned int RxBufStatus; } *EMAC_pRX_descriptor; void Phy_Init(void);
This happens because you are violating the alignment restrictions when reading or writing to memory. An exception will be raised if:
read/write word32: (address & 3) != 0 read/write word16: (address & 1) != 0
thanks for the answer...
and it is ok, if the program write data into the ram to addresses which are higher than the stack ptr address?
Which functions stored their values at this addresses? I've no own functions or variables which pointed to this address area.
Johannes
Well, that depends on your memory layout. Assuming you are using a current MDK version V3.15b, there is a new window called
Call Stack Unwinder
It works in simulation as well as in target mode (e.g. ULINK) and shows the complete call chaining and all local variables/parameters of each call level down to the abort handler. Using this call chain, you can find out which function caused the access to out of area memory. If such a call is unnamed, then it is most likely some library function.
yes I saw this new window called stack frames...
I've installed a function which is called if a data abort occured -> and if this happened then I only see this function and the main function.
The problem is that this error does not always happen when I receive frames by the ethernet. Sometimes I can receive 20 ethernet frames without a problem, sometimes I get 10 ethernet frames, sometimes the printf() message is not completely transmitted (but no data abort), and sometimes I get a data abort (during the receive process)...
And the addresses of the data abort are very often above the stack pointer in the internal RAM, and seldom at addresses which are not defined... I tested all pointers I have installed if they point to such a address - but there's everything ok.
the main function is very small.. I've got three global variables, one extern defined pointer and a little bit code..
volatile unsigned int Emac_Receive=0; volatile unsigned int overrun=0; volatile unsigned int zahl=0; extern EMAC_pRX_descriptor p_rxBD;
or the function are COM1_Senchar() and fputc() (from the retarget function)...
#include <stdio.h> #include <rt_misc.h> #pragma import(__use_no_semihosting_swi) extern int COM1_Sendchar (int ch); /* in usart.c */ struct __FILE { int handle; /* Add whatever you need here */ }; FILE __stdout; //FILE __stdin; int fputc(int ch, FILE *f) { return (COM1_Sendchar(ch)); } int ferror(FILE *f) { /* Your implementation of ferror */ return EOF; } void _ttywrch(int ch) { COM1_Sendchar(ch); } void _sys_exit(int return_code) { label: goto label; /* endless loop */ }
But I mean this function would work by nearly everyone..
My memory layout is.
LOAD_FLASH 0x10000000 0x003FFFFF { EXTERN_FLASH 0x10000000 0x003FFFFF { *.o (RESET, +First) *(InRoot$$Sections) .ANY (+RO) } SDRAM 0x20000000 0x03FFFFFF { phy_init.o (+RW +ZI) } INTERN_RAM 0x200000 0xFFFFF ;INTERN_RAM 0x200000 0x00040000 { .ANY(+RW +ZI) } }
Now I delete the retarget function and the usart.c file so that I only work with the ethernet part... and now the data abort errors are not so often and if one occured then I see nothing in the new window "stack frame"...
There was only one situation were I see an red arrow to one ptr in the lib of the AT91RM9200 (newHandler form the AT91F_AIC_ConfigureIt function)... in the other situation I only see my main function (with the integer i) and the data-abort function which is called if a data abort occured... so it could be probably that there's a ptr who can have every addr at the beginning...
best regards Johannes
I just take a look at the function AT91F_AIC_EnableIt and I don't understand the value of the newHandler, which were shown in the stack window...
newHandler 0xE92D000F (I don't know this address)
__inline unsigned int AT91F_AIC_ConfigureIt ( AT91PS_AIC pAic, // \arg pointer to the AIC registers unsigned int irq_id, // \arg interrupt number to initialize unsigned int priority, // \arg priority to give to the interrupt unsigned int src_type, // \arg activation and sense of activation void (*newHandler) (void) ) // \arg address of the interrupt handler { unsigned int oldHandler; unsigned int mask ; oldHandler = pAic->AIC_SVR[irq_id]; mask = 0x1 << irq_id ; //* Disable the interrupt on the interrupt controller pAic->AIC_IDCR = mask ; //* Save the interrupt handler routine pointer and the interrupt priority pAic->AIC_SVR[irq_id] = (unsigned int) newHandler ; //* Store the Source Mode Register pAic->AIC_SMR[irq_id] = src_type | priority ; //* Clear the interrupt on the interrupt controller pAic->AIC_ICCR = mask ; return oldHandler;
When I'm right, then the newHandler should pointed to my ISR (but my ISR is at the addr 0x100003a0). I just set a breakpoint in the last line of this code, so that the newHandler should already be stored in the AIC_SVR register (which should also store the address of the corresponding handler for the interrupt source).
and that's my call in the c-file..
AT91F_AIC_ConfigureIt(AT91C_BASE_AIC, AT91C_ID_EMAC, AT91C_AIC_PRIOR_HIGHEST - 3, AT91C_AIC_SRCTYPE_EXT_HIGH_LEVEL, (void (*) (void))ethernet_interrupt);
Have you stepped through the assembler, and verified that you don't get a stack overflow when calling AT91F_AIC_ConfigureIt?
How can I check this by stepping through the code?
I have a stack size for the IRQ: 0x00000200 and for the user stack 0x00000600 - I think that must be enough for a small ISR
void ethernet_interrupt(void) __irq { volatile unsigned int status=0; AT91PS_EMAC pEmac = AT91C_BASE_EMAC; // clear receive status register status = pEmac->EMAC_ISR; if (status & AT91C_EMAC_RCOM) // Receive complete Emac_Receive=1; if(status & AT91C_EMAC_ROVR) overrun=1; AT91C_BASE_AIC->AIC_EOICR = 0; // End of ISR }
Now I tested 0x00000600 for the IRQ stack size and 0x00001500 for the user stack size -> and the first attempt was a data abort...
I don't have a feeling how much I need to have enough stack size, but this size seems very big to me for really nothing.. I have only the implemenation of the ethernet and a small main function where I ask if the variable Emac_Receive=1 - that's all
I make some more tests - maybe you could help me to find the problem:
I made the ISR smaller
void ethernet_interrupt(void) __irq { // volatile unsigned int status=0; AT91PS_EMAC pEmac = AT91C_BASE_EMAC; // clear receive status register status = pEmac->EMAC_ISR; if (pEmac->EMAC_ISR & AT91C_EMAC_RCOM) // Receive complete Emac_Receive=1; // if(status & AT91C_EMAC_ROVR) // overrun=1; AT91C_BASE_AIC->AIC_EOICR = 0; // End of ISR }
--> nothing has changed --> I get some data abords when ethernet frames were received.
Then I made the ISR smaller
void ethernet_interrupt(void) __irq { // volatile unsigned int status=0; // AT91PS_EMAC pEmac = AT91C_BASE_EMAC; // clear receive status register // status = pEmac->EMAC_ISR; // if (pEmac->EMAC_ISR & AT91C_EMAC_RCOM) // Receive complete // Emac_Receive=1; // if(status & AT91C_EMAC_ROVR) // overrun=1; AT91C_BASE_AIC->AIC_EOICR = 0; // End of ISR }
Now it seems that I get no data aborts, but if I received frames I can wait plenty of time but the processor always remained in the interupt mode. What's going wrong here, that the processor don't go back to the user mode?
ok I've to read the status register to go back to the user mode.
Only the data abort remained if I receive frames.
I see there two problems: - one could be the call of the ISR -> one ptr who has no correct address (because the data abort happens not always only sometimes when I get new ethernet frames.
- the other problem could be the dma process to store the data --> but the dma have to store the data into the sdram first, and then the interrupt occurred that new data are there... I also check if the data stored in the sdram at the correct place (and that's working)...
- the stack size is really big enough, so that there could be no problem.
- there's nothing in my programm beside the ethernet init
- if there are no new ethernet frames - no data abort
I also think that the error occured when I leave the ISR, because when I forget to read the status register (the ISR is also called and the data is also stored in the sdram) I have no data abort error.
Don't play around at random.
You have yourself said that:
and
If your newHandler pointer is invalid when you initialize the interrupt, then the processor will jump to an invalid location when the interrupt gets trigged.
In that case, it is quite meaningless to look at the ISR stack size. Have you made sure that the correct ISR vector is configured? And that the correct ISR vector is still set when you get to the exception handler?
If - as you say - the newHandler pointer is invalid in the function that configures the interrupt, then there is a total waste of time to continue with the program - you have to find out where newHandler becomes corrupt - is that in the function call, or caused by incorrect code generation at high optimization levels or is it just the debugger that shows wrong values because it thinks that newHandler has gone out of scope, allowing the compiler to reuse a register for something else?
Remember that you may also get other interrupts while initializing the ethernet ISR.
Always try to split your problems into pieces and figure out if the problem occurs before or after your split point. If you don't break your problems into smaller problems then you will never find a solution.
