scatter-file selection
now I wrote a easy scatter-file with three sections (external flash, internal RAM and external SRAM). I tested it and it works.
Now I want to make another section within the external SRAM, where the data should be stored from the peripherial. Therefore I have one pointer (installed in the internal RAM section) which has the address where the data should be stored (within the external sram).
scatterfile-section:
EXTERNAL_RAM2 0x20000000 0x3FFFF
But how could I tell the ptr to store the data within this section?
int *ptr_to_RAM = __attribute__((__at(0x20000000)));
best regards
tobi
