Hi All
I am using AT91SAM7S64 processor for my application i am not able to get the USART0 interrupt up and working .i am able to send data out and can see it on the PC hyperterminal but when i type some thing on the hyperterminal no interrupt is generated .dont know y ....since the same code is working in IAR Embedded workbench .
can any one help me with the working code in Keil compiler .
Regards Suresh
Hello Suresh Kumar,
please take a look at knowledgebase article http://www.keil.com/support/docs/2983.htm.
You may have also a look at example project C:\Keil\ARM\Boards\Atmel\AT91SAM7S-EK\Hello which uses interrupts. Not especially an UART interrupt but the handling should be the same.
Best Regards, Martin Guenther
