I am student and study in AIT. I need example program of Keil-C for use External ram use with IC ADuC832 which address of my external ram has range an address at 0x00000 to 0x7FFFF (512KByte). I want source to write data into 0x800
I atteach my program problem write in C language for test to used XRAM at address 0x00802 by write and read variable t and send value of variable back to RS232.
Please help me sir. Mr.Somphong Thanok ////////////////////////////////////////////////// #include <ADUC832.H> //ADCU832 62 Kbyte Flash #include <stdio.h>
void delay(int i) { int j; for(;i>0;i--) for(j=0;j<1000;j++) ; }
void InitialSerial() { SCON = 0x50; TMOD |= 0x20; TH1 = 0xFA; /* 9600 baud */ TR1 = 1; TI = 1; }
void PutBuf(char c) { SBUF = c; }
void InitialTIC() { TIMECON = 0x00; IEIP2 = 0x44; SEC = 0x00; HTHSEC = 0x00; INTVAL = 70; TIMECON = 0x03; }
void TIC_interrupt() interrupt 10 { t++; TI = 1; //start transmittion printf("%4.4d \r\n",t); TI = 0; //end of transmittion }
void main(void) { unsigned int i; unsigned char k1,dataout; t = 0; CFG832 = 0xC1; PLLCON = 0x00; InitialTIC(); EA = 1; while(1) { } }
Last I checked, students were supposed to study.
The manual for the Keil toolset, which you should study, has this information and, as you have not picked this particular bit (xdata) up, since without such fundamental knowledge you will be lost anyhow till you read the manual. I will even assume it will be in the 'getting startd guide' that you should work through (NOTE "work through", not "read") before attempting anything as Keil novice,
