You can use the void pointer function sample in simple programs but if you want to use software reset in interrupt routines you can act like this: by calling the int. routine and coming up your condition it will jump to 0x0000 Also the "addr" is unsigned char and SP set as compiler defaults.
void t0_service(void) interrupt 1 using 3 { addr=SP; /* Your Code */ PSW=0; if( /*your condition to jump 0x0000*/ ){ *(unsigned char *)(addr)=0; *(unsigned char *)(addr-1)=0; *(unsigned char *)(addr-2)=0; *(unsigned char *)(addr-3)=0; *(unsigned char *)(addr-4)=0; *(unsigned char *)(addr-5)=0; *(unsigned char *)(addr-6)=0; *(unsigned char *)(addr-7)=0; return; } }
http://www.keil.com/support/docs/307.htm
