Problem setting pointer via function
I have a problem when I try to get a function to update a the address of a pointer.
Code:
const unsigned char array1[10] = {1, 2, 3, 4....}
void func1 (const unsigned char *ptr)
  ptr = array1;
void func2 (void)
  const unsigned char *ptr1;
  func1 (ptr1);
  if (ptr1[0] == 1)
The problem is, the ptr in func1 gets the right address, but when I return to func2, ptr1 doesn't get updated. I have tried to remove the const from the variable definition in func2 without any succes.
array1 must be defined as a const because in the real code it's a lot bigger.
I have tried to set ptr1 directly in func2.
void func 2 (void)
  ptr1 = array1;
  if (ptr1[0] == 1)
This work fine. But this is not an option in my application.
uC: STR712
compiler: CARM
  • Try this:
    void func1 (const unsigned char **ptr)
      *ptr = array1;
    void func2 (void)
      func1 (&ptr1);
      if (ptr1[0] == 1)
    Actually this is textbook C stuff. You might want to consult your favorite C book once more.
    - mike
  • "Actually this is textbook C stuff. You might want to consult your favorite C book once more."
    You need to review how 'C' passes parameters to functions - it passes by value only...
  • The problem is, the ptr in func1 gets the right address, but when I return to func2, ptr1 doesn't get updated.
    That's because func1 only gets a copy of the value of ptrl. It cannot modify ptrl with this.
    Essentially, func1 in its present form does not do anything.
  • "update the address of a pointer."
    That might be just a typo, or a problem with English, or it might illustrate a fundamental misunderstanding:
    You cannot update the address of a pointer.
    A pointer is a variable like any other - it occupies a certain location in memory, that location is called its address, and it is fixed at build-time by the tools (or possibly at load-time by the loader, if you have such a thing).
    The value of a pointer is also an address - it is the address of the pointed-to thing (the "target" of the pointer).
    Again, check your 'C' textbook on this!
  • That solved the problem..... Thanks
    I did mean change the address the pointer is pointing to not "update the address of a pointer." ;-)
    Thats the problem when my text book i missing.... :-(
