remapping bank0 of STR912 device
On the ST site there is a example of in system programming using an UART.
This code must be programmed in Flash bank 1 wich has to be rempapped at adres 0x00.
Is this possible using ULINK with real view ? What are the settings to do this ?
I have some bad experience with remapping. Some time ago I had to replace the device because it could not programmed with the ULINK ....(See another thread in this list)
Luc
