I am using LPC2138 and I'd like to set it into power down mode to conserve power. Based on the data sheet, LPC2138 is able to wake up by RTC (Interrupt Wakeup Register - INTWAKE, bit 15) What i have done is enabled RTC intterupt before i set LPC2138 into power down mode (Power Control Register - PCON, bit 1). However i failed to wakeup the LPC from power down mode using RTC. The board hang when i executed register PCON = 0x02 (power down mode).
For your infomation, the RTC intterupt is working properly and the whole program is runing well if i disabled/mark out register PCON = 0x02 (power down mode).
Is there anyone can give a hand on this? TQ.
What do you actually mean by the board hang. The Embedded ICE is not available during power-down (so ULINK will stop working). Is this what you see?
No, i not running it on debug mode but I just flash the software and run the application on the development board. I turn ON the 1st led before executing the command PCON = 0x02 (power down mode) and i also set the 2nd led to be ON if the RTC interrupt is occured after 20 seconds.
From the result, the 1st led is ON but the 2nd led is off anyway. I am in doubt the RTC is halting in power down mode.
Please advice. TQ
