Hi All,
I am using uVision3 and RV compilar with LPC2000. Who can I reserve in the on chip FLASH memory an area that the compilar will no put there a code. I need known memory reserved area for downloading an external data.
Thanks Kobi
You can use the scatter loading file.
Either you can reserve a section of memory for your data or you can put your code at specific address of memory.
Suvidh
TNX
Do I have to use IAP in order to place txt file in the reserved memory area or I can use the linker? If yes, How?
Kobi
If your Text is Fixed and is to be loaded design time You can define it as an "array of constant" in a section or a different file.(say file.c) const char abc[]={content} In your scatter loading description this file.o goes to the required rom section/address.
Hi
I need to add an external text file. Currenty I am planing to load it with the IAP, but if there is easier way, I will be glad to learn.
Thanks kobi
