Is that the LPC2103 will resume the next command once either one of the external input interrupt pin is enabled? Or it will reset the whole program?
After the LPC wake up from the external input interupt, what are the setting/register that we should properly set for it (before and after power down mode) so the program will run well after power down mode?
Thanks.
Amendment for the mcu above, it is LPC2138. TQ.
